what bike it comes from?
ligurt
Post by ligurt »
Can you tell me what bike this wheel comes from? Is it rc30 or rs250 or what else? And is there a way to fit on the nc30/35 hub, or which mods are necessary?
Yakama
Re: what bike it comes from?
Post by Yakama »
RC30 HRC mag? An RS250 would have the spokes the wrong way round for an NC30. Should fit an nc30 but you will need the rc30 spacer part no 9 here:
https://www.cmsnl.com/honda-vfr750r-rc3 ... ml#results
ligurt
Post by ligurt »
Yakama wrote:RC30 HRC mag? An RS250 would have the spokes the wrong way round for an NC30. Should fit an nc30 but you will need the rc30 spacer part no 9 here:
Thanks Yakama, spacer would bre the less, but what about the diameter? Would the nc30 hub and spindle work correctly?
RickOliver
Post by RickOliver »
I would suggest that it`s an RC30 race mag which someone has modified to fit an NC30 by adding cutouts to clear the disc bolts (see this thread - viewtopic.php?f=22&t=53881)
Contact me if you are in need of an RC30 wheel spacer.
Rick
ligurt
Post by ligurt »
RickOliver wrote:I would suggest that it`s an RC30 race mag which someone has modified to fit an NC30 by adding cutouts to clear the disc bolts (see this thread - viewtopic.php?f=22&t=53881)
Rick
Thanks a lot Rick.
My intention is to fit the 4,00-18 rc30 rear wheel, I don't care to fit a large size tyre. The 150/60/18 is perfect for my project and it would have to fit on the 4 inches rim. My only misgiving is about the centre bore that is 40mm on the rc rim and 45mm on my magtek and related spacer/center lock. How much would it cost?
Is there an rc30 4,00-18 rim in the surroundings. I could also swap for my perfectly restored 4,50x17 magtek.
