Ebay Alloy Rad opinions.
Posted: Fri Aug 04, 2017 9:50 pm
by RandomDan
Hello all, long time since i last posted here!
I want to gauge the general opinion of the ebay special ally rads you can get.
Mine it a combination of filthy and corroded i could sit there with a cable tie to try and clear it but life is too short for that!
Obviously at the time like anyone else i dont want to waste money on crap either :)
So by all means chuck your two pence in and let me know!
Re: Ebay Alloy Rad opinions.
Posted: Fri Aug 04, 2017 10:40 pm
by icklepob
Spot on for the money. I got an R1 one for my YZF750 racebike and they are amazing for the money. May need a little tinkering to the outlets that aren't perfectly round, but it's not worth not buying one.
I've just got a thundercat one for my 400/600 and again, for £65 it's really good.
Sent from my SM-G950F using Tapatalk
Posted: Fri Aug 04, 2017 10:54 pm
by icklepob
New thundercat rad ImageImageImage
Posted: Sat Aug 05, 2017 10:03 am
by RandomDan
Thats about what i expected to be honest, there wouldnt be so many around if they werent usable.
Replacing them at around £70 is certain simpliar than trying to clean them not to mention the coral corrosionitus.
Posted: Sat Aug 05, 2017 3:51 pm
by icklepob
Had several between me and mates, for mx, enduro, race bikes and specials. Always been 95% perfect with minimal tweaking for make perfect.
Posted: Sun Aug 06, 2017 10:34 am
by vic-vtrvfr
Be careful.
Some ebay rads have a straight top rad instead of curved and an create fitment issues.
Scott Jellyman has supplied replacement rads to half the NCs in the country, great value and work really well. Give him a shout
Posted: Sun Aug 06, 2017 10:46 am
by RandomDan
vic-vtrvfr wrote:Be careful.
Thats a good shout!
The one i was looking at has a straight top!
Actually most of the ebay ones are straight unless you buy them straight from china... weirdly
nevermind found scotjell :)
Posted: Sun Aug 06, 2017 10:04 pm
by Dynamohum
I noticed on graeme france website that the rads he sells have replacement japanese made caps as the chinese caps are wrongly pressure rated for nc30/35
Ive used the gpi rads without any issues so far however based on that will now take his knowledgeable findings on board and get a replacement cap.
Posted: Tue Aug 15, 2017 11:04 pm
by BB_158
Yes be careful of the cheapest ones. I rejected a set and got a refund as the mounting brackets were all over the place.
Posted: Thu Aug 24, 2017 1:50 pm
by RickOliver
With reference to the mounting bracket problem, there is a substantial difference between the top rad upper brackets on the NC30 and the NC35 - the RVF has short, upright brackets on the centre line of the rad, the VFR has longer, angled brackets which offset the mount well to the rear.
A lot of Chinese manufacturers seem to have used the RVF rad as a pattern and assumed that it will fit both models, which it won`t.
Scott J. has taken the time to sort those issues out with his supplier which is why the rads that he supplies actually do fit...
The correct radiator cap is 1.1 bar, not the more common 0.9 which is often supplied.
Rick
