VFR400 carburetor assembly issues
RizomaKat
- Bike owned: RVF400RR VFR400 NC24
I have removed the carburetors from my recently acquired non running VFR400 NC24 with the intention of cleaning them and discovered that the drain screws are not all positioned on the outside. According to the carb jetting instructions, which someone has kindly posted on this site, all four drain screws should face outward.
I have successfully worked on my RVF400 carbs but I have a trusty Haynes for that bike.
Could anyone tell me if this means the carbs have been swapped around or previously reassembled incorrectly?
Will they function effectively in their current position or do I need to disassemble and switch them around?
Sent from my iPad using Tapatalk
- Bike owned: VFR400
Re: VFR400 carburetor assembly issues
Last time I had this problem the solution was to swap the float bowls around, not the carbies.
hunter
All those float bowls are the same hand.
And i'm pretty sure it's the way the 24 came.
RizomaKat
Thanks that would be logical if shifting around is the way to gomagg wrote:Last time I had this problem the solution was to swap the float bowls around, not the carbies.
RizomaKat
Appreciate your input hunter, it probably is the way the carbs come on an NC24. I found breaker's markings on the fuel pump and carbs, so wondered if they had been fettledhunter wrote:All those float bowls are the same hand.
It's correct.
Top left / Bottom right (when on the bike) or flipped upside down with front bank of carbs towards you bottom left / top right float bowls drain screws face inwards..
long screwdriver through the V will open them.
a lot of the carb guide refers to the nc30 carbs.
