				START BUTTON CAUSES REV COUNTER TO RISE TO 6THOU REVS..?
				Posted: Tue Dec 02, 2008 11:26 pm
				by Q007
				When i turn the ignition on and switch kill to run it clicks like normal (fuel pump priming) but when i press start it whirrs and rev counter needle rises to about 6 thousand revs but engine is not turning over,anyone ever heard of this problem...?
please help it's making me go insane...!
cheers in advance
Q007
				Re: START BUTTON CAUSES REV COUNTER TO RISE TO 6THOU REVS..?
				Posted: Tue Dec 02, 2008 11:32 pm
				by Marb
				If it revs to 7 it means the CDI isnt responding properly. If it reads 3rpm more than it should ie. revs at 4 grand then it is the fuel pump.
Havent heard of the 6rpm reading.
				Posted: Wed Dec 03, 2008 10:44 am
				by Evilchicken0
				I haven't hear of any of that !!!
				Posted: Wed Dec 03, 2008 11:26 am
				by Alex.
				Sounds to me like it could be a weak battery.
It may have enough juice to prime the fuel pump, but not enough to turn the engine over.  That and rev counters can do some really wierd things with dodgy batteries!
Alex.
				Posted: Wed Dec 03, 2008 11:53 am
				by Taggyd
				check to see if the battery terminals are getting warm, if they are it could be that you dont have a good enough connection/furring up of the terminals, give em a clean up and tighten if that dont work it could be the battery is on the way out/flat as mentioned! had this on another bike once was cleaned started no problem!
				Posted: Wed Dec 03, 2008 1:40 pm
				by Q007
				Charging battery now....really hope this is the problem....otherwise it's bound to be exspensive.....
 WOOT WOOT WOOT JUST THE BATTERY......!
CHEERS GUYS
Q..
				Posted: Wed Dec 03, 2008 3:22 pm
				by Evilchicken0
				If it turns out the battery is duff (doesn't hold charge) then I get them from MDS
				Posted: Wed Dec 03, 2008 9:43 pm
				by Motorcycle Solutions
				you can fit a ytx12bs battery in replace of the 9bs which will keep longer.....
pm me for price and 400 members get 10% of the selling price and postage is in the price..
