Leaking forks
saltysealion
Leaking forks
Hi,
rebuilt my forks because they were leaking. One side has held well now but the other is leaking.
I have replaced both dust and oil seals, o-rings in them with genuine parts.
What other causes could there be for such leaks? The sanctions on the leaky side looks good.
- Davez29
- Bike owned: NC29 forever
Re: Leaking forks
Have you possibly torn the edge of the seal while pulling it down the stanchion. Best use a thin oiled plastic bag over the end of the stanchion while sliding the seal into place.
saltysealion
Re: Leaking forks
I did protect the seals when sliding them over carefully. The other side isn't leaking.
I will get a chance to inspect them when I pull them off but at the moment, I think they are fine?
- Bike owned: VFR400
Re: Leaking forks
Worn bushes may be causing seal lip distortion, that lets oil weep past.
saltysealion
Re: Leaking forks
I'll get new bushes for this next tear down to eliminate that possibility as well... I did inspect the when I had the forks apart and they looked fine. No major marks or anything but maybe it just has wear on it.
Should I replace the guides as well? That is replace:
51414MW4003
51415MW4003
Ah, the one thing stopping me from enjoying the bike!
51414MW4003
51415MW4003
Re: Leaking forks
An indication of any movement can be obtained by removing the dust and oil seals and then fixing the inner tube and rocking the outer tube at various extensions. Also the outer tube inner surface can become worn oversize by the inner tube guide. New guide bushes unfortunately cannot remedy this condition.
saltysealion
Re: Leaking forks
Magg, do you mean the sanctions may just be over worn?
Re: Leaking forks
Worse case, yes. The teflon coated bushes might be intended to slide easily but they still appear to wear away at the aluminium surface, possibly because suspension forces distort the alignment of the telescoping tubes. Better designs, Ohlins and some up market Japanese types use a fixed upper bush inside the tube, so that the steel inner tube always slides on the teflon surface and never touches aluminium.
saltysealion
Re: Leaking forks
Just to close up this thread, I did another rebuild on just the leaking fork.
I replaced the oil seal (again) and bush. Nothing was visually wrong with the existing OEM seal I took out, but I replaced it anyways. I used a quality after market seal since I did not have an OEM at hand.
So far no leaks so I am very happy. My bike feels great and STAYS great.
