yoshi tmr/mjn Vs fcr33
Posted: Mon May 01, 2017 2:35 am
by Nobbsie
Does anyone have real world experiance? I herd that the yoshi tmr/mjn are better for low to mid power, is this true?
P.s with them being 32mm you could keep higher intake velocity?!
Re: yoshi tmr/mjn Vs fcr33
Posted: Fri May 05, 2017 3:50 pm
by Variablevalves suck
Hi,
They are basically the same by different manufacturers so only slight differences.
I have TMR's on my sp and they come with the low speed pump and a choke, im sure FCR have no choke and the pump is an add on, may be wrong.
They come in 28 mm out to 33 mm so lots of choice in diameter.
Posted: Sat May 06, 2017 9:08 pm
by Nobbsie
Kool thanks for the info!
Nobbsie
Posted: Sun May 07, 2017 10:10 pm
by morris147
i looked at the idea of getting a set of zxr400 carbs spaced out for the 76a, only for the reliability and to see if some sort of ram airbox could be set up.
