I had an incident, bike shop diagnose as OK - Input please!
Posted: Thu Feb 16, 2017 11:46 am
So I had stupid moment by that I mean i'm an idiot and shouldn't be allowed to work near bikes.
I went to fit the new handle bars on my CBR400 at the weekend, had the bike on a paddock stand and a jack underneath it was all supported well. (it wasn't)
I dropped the forks out of the top yoke and all was going well, next thing i know the bike slips off the jack then off the paddock stand and basically collapses.
The problem being the forks where still on the bike; albeit all the pinch bolts were loose, but what happened was the forks obviously tried to find there way out as they were no longer held in place but couldn't because the angle meant they jammed in the bottom yoke.
I couldn't hold the bike and let it go.
By this time the bottom yoke fork clamps had twisted and were pinning the forks in. Hard to describe but the forks wouldn't budge because the hole for them to go through wasn't straight as yoke clamps had bent up.
A bit like this. (looking at them straight on)
So we knocked with a hammer the yoke fork clamps back straight again so the forks would slot through, the gap between the clamps was quite larger but with some more hammering they got close and eventually the pinch bolts would go through ok and pulled everything tight.
I got everything back together and the bike standing again,
Things i have noted:
>The stanchions didn't look bent and were free from any major marks or dinks
>The bottom yoke didn't look damaged and there didn't seem to be any stress cracks or marks
>The frame etc took a hit but only a scratch
>The gear lever was bent but now straightened
>When fully compressing the forks when stationery there is an odd crunch / springy feel right at the bottom of the reach
With all this said I still took it to a local bike shop to check it over. They have come back saying the forks are not bent, the yoke looks ok and nothing is adrift.
I am not an expert and to be fair the bike does ride fine but it does have that noise mentioned above (only noticed when stationery) and the state it was in I just can't believe there was nothing wrong with the bike. I was amazed the yoke fork clamps hammered back together they seemed malleable rather than a solid piece of metal.
Sorry for the long post and rambling but I thought why not.
