1989 NC30 Project / rebuild
Posted: Mon Feb 13, 2017 1:05 pm
So, this is my first go at getting stuck in myself and rebuilding a motorcycle. I should've started the post right from the start but never got round to it. It's not a complete 'nut & bolt' restoration, maybe a 60% ish restoration (I don't have the time, skills and money to do a 100% restoration).
I will begin with a photo of the bike when I purchased it and where I'm up to now. I've also just purchased an aftermarket fairing kit so will do a bit of a review on that when it arrives, hopefully in a months time the bike will nearly be done, ready for the nice weather! I've personally enjoyed reading through other peoples restoration posts whilst picking up hints & tips etc. so hope people can take something from what I've done likewise.
So when I got the bike it was't running properly and had terrible looking aftermarket 'West' fairings, but that's subjective I suppose...
Firstly I purchased an Abba stand and began to strip down the bike down so I could replace / clean things.
Currently I've done the following:
Remove exhaust, replace gaskets, removed rust, polish. To de-rust the system I soaked it in a solution called Deox-C rust remover which is unbelievable stuff!
I decided to start from the back end for some reason so had the subframe, wheels, various brackets and the stand powdercoated. Sonax plastic restorer was used on the undertray, turned out quite nice. New tyres also...
Standard shock replaced with S1000RR shock from Ebay, filed the top mount down slightly and it went straight in. I've also purchased a custom spring for this but for now, I'm going to try it with the standard BMW spring fitted since I will just be using it on the road.
It's surprising how well things clean up, honda build quality I suppose... I wish it was easier to upload photos on here so I could dump them all on.
I've also had the forks powdercoated grey now, the top yoke powdercoated and clock brackets, handlebars etc. I've fitted a rear HEL braided line and a chain guard.
Some more stuff I've completed:
- Forks rebuilt with Rick Oliver springs, new bushes, seals etc.
- Tidied up the wiring loom.
- A lot of general cleaning, polishing & de-greasing
- New chain & sprockets
- Removed Rads (not sure how I'm going to tackle restoring these yet)
- Calipers powder coated and rebuilt with new seals and any other replacement parts required
- New Tyres
- Clocks cleaned and re-fitted to powdercoated brackets / mounts
- Replaced throttle cables
- Cylinder compression test
- Rebuilt fuel tap
- New spark plug coils
- New shock linkage bolts
- Re-painted a few brackets myself
- New brake pads
I'll upload a mix of various photos below...
(annoyingly some of my photos wont upload)!
Hopefully this weekend I can get the front end built back up! Thanks for having a look... I will hopefully post every Monday with progress updates...
Rick
- New Tyres
- Rebuilt fuel tap
- New brake pads
Rick
