VFR/RVF long fairing bolts
- Davez29
- Bike owned: NC29 forever
Hi, can anyone tell me if the long pan fairing bolts (6x22) 90112-ms2-000 from the nc29 are the same as whats used on the vfr/rvf fairings please? If so, what part numbers they are.
They look like this: http://www.partzilla.com/parts/detail/h ... 2-000.html
cheers
Dave
cheers
Dave
Foxy400
Re: VFR/RVF long fairing bolts
I'm pretty sure those bolts are not used on either the NC35 or NC30. If you go to the cmsnl.com website you'll find details and part numbers for every part used on those bikes. Look at the schematics for the fairings and you won't find that part listed. I've just had a quick look and couldn't find it.
If you google your bolt part no. you'll find a long list of bikes which use it. Unfortunately neither the RVF or VFR are there.
- Davez29
Hi Foxy, thanks. I did goto CMSNL but to be honest I was unsure as I couldnt find them but assumed they would use them on the 35 at least as its just a fairing bolt. Im just trying to sort what the part number would be on another Honda so I can order a Titanium version from Ebay as my PN is not accepted, as usual its a pain.
cheers
cheers
- JZH
- Bike owned: RSCBRRVFVFRST
US-based sites usually don't have non-US parts or compatible models listed, and vice versa. That bolt is listed on Partzilla because it was originally used on the CBR1000FK-L, which was sold in the USA (as the "Hurricane 1000").
The bolts you're thinking of are pn. 64508-mr8-000, which are 17mm long with a 6.5mm shoulder (and cross-head). Might still work on the NC29, but 5mm shorter might be a problem. I don't see any titanium replacements available for that bolt, but a US eBay seller appears to be selling stainles steel 20mm-long versions.
Ciao,
Ciao,
