NC35 Lower Fork Leg Disassembly
RoninZX-10R
Bike owned: NC35 racebike, ZX10R roadbike
Post by RoninZX-10R »
Sometime during the racing season the left hand lower fork leg has taken a hit and has bent one of the arms (not sure if that's the correct term?) that the caliper bolts to. Now when I tighten the 2 bolts to secure the caliper it twists out of alignment with the brake disc, making it rub.
To fix this I want to remove that section of the fork leg to realign it. What I can't work out is whether the fork tube will slide out of the lower section, or if it's something more complicated?
Re: NC35 Lower Fork Leg Disassembly
Theres a grub screw that needs loosening off then the tube unscrews although im sure honda never wanted anyone to remove them as there a complete bitch to unscrew. Lots of heat is the order of the day
JZH
Bike owned: RSCBRRVFVFRST
Post by JZH »
Heat due to the adhesive / threadlock they used, but the other issue is how to safely grab the stanchion to unscrew it without damaging it. I've seen them clamped into big lathes. If there are holes in the tube you might be able to stick something in there to hold it. Bending the alloy lower tab the other way might not work anyway, tube in or out...
Ciao,
JZH
London, UK/So.Cal., USA
www.vsource.org
RoninZX-10R
Ooh bugger, that doesn't sound like an easy job. Might need to have a word with my suspension guy.
Thanks for all your help DM and JZH, much appreciated.
Malc
Bike owned: NC35, 5SL, 3XV, 2MA
Post by Malc »
Usually two holes at the far end of the tube to assist in unscrewing. As DM said, total c*** of a job.
