Nc30 not sparking correctly
- One Hit Wonder
I have a Honda VFR400R Repsol Nc30, it idles but sound rough, front coil spark is strong, rear coil is weak, the pulse generator only reaches 0.7v instead of a minimum 1.8v, battery charges perfectly and increases charge when revving, what could be the problem, I hope its not an expensive issue, please Help Someone
- Bike owned: VFR400
Re: Nc30 not sparking correctly
How are you measuring the output voltage of the pulse generator? With the headlight off, what voltage do you measure across the battery at 5000 rpm?
