Page 1 of 2
				1WG Inlet manifolds on a 3TJ ?
				Posted: Tue Sep 06, 2016 9:01 am
				by ArronA
				Hi people
The inlet rubber manifolds on my 3TJ are cracked around the top quite badly, when i had the bike fired up it had a really strong smell of fuel and i could see it weeping from the manifolds, i can't seem to find any replacements for the 3TJ anywhere but the 1WG ones are available from a few sellers on eBay, has anyone tried this? i know there is around 15mm give or take in the over all height between them and the 1wg manifolds are slightly slanted and marked L L & R R as apposed to the more shorter not slanted 3tj ones that are marked 1, 2, 3, & 4
I think the 1wg ones are a better design as there is less rubber that can crack and go bad but I'm unsure weather if i get some and fit them my airbox might be bumped up higher and sit differently meaning that the fuel take won't seat correctly
Any suggestions? Thanks!
				Re: 1WG Inlet manifolds on a 3TJ ?
				Posted: Tue Sep 06, 2016 9:09 am
				by willandrip
				This is the standard work around solution to the NLA 3TJ units.
Quite a few members have gone down this route.
They raise the air box a very slight amount..5mm IIRC but not enough to prevent the tank cover fitting correctly.
Check prices with CMSL and factor in carriage...they MAY beat Ebay vendors.
Pretty sure Drunk'n Monkey will spot this thread....he was eventually convinced to do it this way after numerous other options failed.
Southend Chris was the originator of fitting these  I believe.
				Posted: Tue Sep 06, 2016 11:54 am
				by ArronA
				willandrip wrote:This is the standard work around solution to the NLA 3TJ units.
So it's a straight switch over with no modifying ? and the slant on the 1wg inlets don't make anything clash with anything ? (sorry to sound dumb but what does NLA stand for?) i have been thinking about buying a set of 1wg inlets for ages but I was worried about buying them and then finding out they won't go on or cause complications or something because i don't really have enough money to waste lol
I guess both the L manifolds go on cylinder 1 & 2 and the R ones go on cylinder 3 & 4 ? also do they just need to be any 1wg inlets or do they need to be 1wg ones from a particular year ? (sorry for all the questions!)
Thanks for the reply i really appreciate the advice
				Posted: Tue Sep 06, 2016 7:54 pm
				by willandrip
				No Longer Available.
The ONLY available manifolds are 1WG GENESIS fitment. 86/87
				Posted: Wed Sep 07, 2016 9:21 pm
				by ArronA
				Also my oil light doesn't go out although I've drained and replaced the old oil and filter and filled it up to the correct number that is on the side of the engine casing (can't remember what it was off he top of my head, 2600 or 2900ml or something)
Didn't want to waste space by creating a new thread ?
				Posted: Wed Sep 07, 2016 9:43 pm
				by Evilchicken0
				That might be a short on the oil circuit .. the oil pressure switch / sender is buggered
				Posted: Wed Sep 07, 2016 11:19 pm
				by willandrip
New subject totally off original topic = start new thread...it makes for easier info searches in years to come.....
The same amount of space is used (bandwidth) = cyberspace...lol....its not like paper you know ?
				Posted: Wed Sep 07, 2016 11:27 pm
				by willandrip
				Evilchicken0 wrote:That might be a short on the oil circuit .. the oil pressure switch / sender is buggered
Pressure switch or level warning lamp on a 3TJ  Boris ?
All pre 3TJ,s are level indicators I do know.
O.P > find the switch, uncouple the wire...if the lamp goes out it is a switch fault , if it stays on the wiring for that circuit is earthing out. This is for level switches.
For pressure switches... uncouple and then  earth the wiring to test the switch. The oil pressure keeps the switch open and the lamp  unlit.
				Posted: Fri Sep 09, 2016 6:11 pm
				by Evilchicken0
				Sorry level switch
				Posted: Fri Sep 09, 2016 8:00 pm
				by willandrip
				Evilchicken0 wrote:Sorry level switch
Never apologise...it's a sign of weakness....accredited to Ralph Barger..
Anyhow...not like you to make that error mind Boris...
O.P. Any joy ?
