Fzr 400 3tj forks change
swadger25
Post by swadger25 »
Hiya I have a Fzr 400 3tj model
Looking for forks for my bike .
Maybe a upgrade to some thing
What will fit on ??
Mate has Fzr 600 3he front end was told it would fit rite on any ideas ?? Thanks
Re: Fzr 400 3tj forks change
Post by Evilchicken0 »
Fzr600 forks are 38mm diameter where as 3tj are 43mm. The 3tj RR non adjustable forks are Ok for the road, rebuild them with new springs and oil and you'll be fine. Replace the shock if you can
willandrip
Post by willandrip »
swadger25 wrote:Hiya I have a Fzr 400 3tj model
What will fit on ??
A 3HE front end is not really an upgrade..the suspension is infact poorer and less ridged than a 3TJ.
The only bonus is if they are post 1989 then blue spot calipers are a straight bolt on fit.
Research cartridge fork emulator valves as a means of a cheap effective upgrade c/w new uprated springs
Racetech are leaders in this field.
I have some pair of old forks but they have some rust on the stachions in various stages
