nc24 fork help needed
Hi all, need help with rebuilding the left fork on my 24 - i did have it all laid out neatly on my bench until my daughter had other idea's, now I cannot remember which item goes back in which order. I have looked at the blown diagram on CMSNL but it is not clear to me.
Looking at the diagram is it rebound spring(8), oil lock(16), leaf spring(5), washer(6), leaf spring(5) all on the end of the pipe seat(37) and into the fork lower?
It looks like the oil lock sits on top of the rebound spring - is this correct?
Any help is much appreciated as usual.
- Bike owned: VFR400
Re: nc24 fork help needed
Not familiar with NC24 forks but generally spring 8 would slide up tube 37 and then tube 37 is dropped into the top of tube 32. Tube 37 should then poke out the bottom of tube 32 and the oil lock ring 16 then slid onto the end of tube 37. Tube 37 and all the included bits then placed into lower leg and screw 43 holds it altogether. Items 5 and 6 are a mystery to me unfortunately but can only assume they sit on top of the oil lock ring as it is slid onto tube37.
Thanks magg, its not clear on the images is it - thanks anyway.
No, they tend to show contradictory left and right layouts.
