Nc35 trouble starting and idleing
Posted: Mon Jul 11, 2016 9:44 am
by Mavirick
Hi all
Having some issues with my NC35
When the bike has been standing for a night of a few days i have a massive mission to get her started and if i do get her going she battles to idle and rev up.
Ive run out of options please help
MAV
Sent from my SM-N910F using Tapatalk
Re: Nc35 trouble starting and idleing
Posted: Mon Jul 11, 2016 11:11 am
by magg
Starts easy once warm?
Posted: Mon Jul 11, 2016 5:58 pm
by RichardJ
Carbs balanced, valves clearances checked?
Posted: Tue Jul 12, 2016 12:01 am
by Mavirick
Most of the time yes...valve and carbies are fine when she is still a bit coldish when you pop the the throttle revs drop and she dies
Posted: Tue Jul 12, 2016 3:45 am
by magg
They all need some warmup from cold.
Choke and vacuum tap working correctly.
Personally found that converting vacuum fuel tap to fully manual improved the startup if the bike had not been used for a few day. Think fuel evaporation and slow float bowl refill, as consequence of limited vacuum during cranking, may have been the issue.
Posted: Sat Jul 30, 2016 5:09 pm
by Mavirick
Mag your manual tap from what bike is that or how did you convert it
Posted: Sun Jul 31, 2016 12:34 am
by magg
Used the guide in the HRC TT formula 3 setup doc from this site library. Rearranged the tap internals using the spring to keep diaphragm open and plugged the vacuum hose from the intake. Apologies for the lack of clarity, been a while since I did it.
Posted: Sun Jul 31, 2016 7:30 am
by Mavirick
Awesome thanx
Posted: Sun Jul 31, 2016 9:46 am
by Mavirick
Magg can you send me link please
Posted: Sun Jul 31, 2016 1:10 pm
by magg
