CB400 Top End Speed Issue
Posted: Thu Jun 09, 2016 8:26 pm
Hi,
I have a 95' CB400 that won't go faster than 90mph/150kph.
I have been messing about with the bike since I got it about a year ago. I finally have some time to try and get to the bottom of it.
Any advice is greatly appreciated as this has been bugging me for so long.
From 1st gear to 4th the bike is a beast, it's super smooth, surprisingly fast and everything seems to work as it should. 4th gear is where the acceleration ends. 4th gear gets me to 90mph at the redline, 5th gear will sit at 10,500rpm/90mph and 6th gear can't sustain that speed so the revs drop.
The bike/setup was a mess when I got it. Valves needed done, don't know who messed with the carbs but they shouldn't be allowed to touch anything mechanical.
Anyway, done the clearances and the carbs have had a complete split. In the process replacing orings, replacing jets and adjusting mixtures.
Read everything I can find on the 180kph restriction, which is stressful in itself when my bike can't get close to that. Just in case, fitted the resistor to the clocks and tried speedo convertor with no success.
I've used the colortune to check the mixtures with the engine in neutral, bit more difficult at 90mph.
The plugs come out ok after run but I really need to kill the engine at 90mph in 5th and check them roadside. Which is next on the list.
Anyone experienced this sort of issue?
