What alternative nut and bolt can I use?
chownsy
- Bike owned: KS125, ER5,VFR400 NC24
I have been replacing all my bolts where I can with stainless to improve the looks of the bike.
I have got stuck on the rear sprocket bolts. 6x M8 with a collar and special nut. I however cant use standard as it appears 4 of the 6 were lost before I started to strip this down again recently.
Ideally I could do with Nyloc nuts onto what ever I choose to replace the bolts with
Can someone help me out as google search aint bringing up many options.
Dynamohum
Re: What alternative nut and bolt can I use?
Try eBay search for m8 staytite stainless locknuts they are a bit closer to the original Honda nuts with a metal locking insert similar to o/e fitment Without the rusting a bit nicer than nyloc IMO.
chownsy
I will have a look thanks
I need to sort some thing out for the bolts as I cant use normal bolts as then the sprocket moved on them due to the size differences
- vfrman
- Bike owned: NC30, 1098s
The locknuts with the metal locking collar are called fuji nuts.
http://www.amazon.com/Bolt-Motorcycle-H ... entries*=0
- JZH
- Bike owned: RSCBRRVFVFRST
I have a set of OEM ones off a spare NC24 swing arm I acquired for no discernable reason. You're welcome to them, but they're not pretty!
Ciao,
Ciao,
