Rear shock to soft
Jay1200
- Bike owned: gsxr 750, drz400, nc30
Rear shock to soft
Hello
Is there anything I can do with my rear shock?
It's really soft and I bounce all over the place
The preload only goes 2 turns from lock to lock and it's currently set about half way on the Spring.
When funds get better il get a bmw rear shock but i need to sort front forks this month
- jim157
Jay1200
Re: Rear shock to soft
Ok
Is there a manual to that anywhere?
- Bike owned: VFR400
"The preload only goes 2 turns from lock to lock and it's currently set about half way on the Spring." Could you expand on this statement, not sure I understand you your are adjusting. Can you describe the type of shock and the adjustment available.
Jay1200
Ok so half way on the preload
Then Spring is wound about half way
It's the standard shock
Standard for which model, does it have rebound damping adjustment and remote reservoir? Spring preload should be adjusted for ride height and will have more than 2 turns. Damping adjuster is for spring motion control. If the rear end is "bouncing all over the place" and there is no damping adjuster or it does not have the desired effect, then as jim157 suggested, your shock needs a rebuild. Shock rebuilding is not covered in the Honda service manual and is a specialist operation.
Jay1200
Ok thanks
It an N model
Any idea who rebuilds these?
It an N model
What country? So it has a remote reservoir and rebound adjustment. Have you tried adjusting the rebound adjuster?
Jay1200
Where's the rebound adjuster?
I'm in England
I'm in England
On the lower shock mount, slotted screw slot. Not UK based cannot help with rebuild.
