Installing restrictors?
Stockko
Should the restrictor washers be pushed down to where the rubbers meet the metal? If so any tip on how to do so?
upload img
upload img
crookzy1
Re: Installing restrictors?
They fit in the rubber within the groove.
sleepyboy
- Bike owned: Too many to list
Hi matey , just a quick question , are you installing the restrictors for a test? or just restricting the bike for personal use. I only ask because you might want to look at the Certificate of Conformity , although not a legal doc someone might want to see it to prove the bike is restricted, just a thought.
www.gov.uk/motorcycle-practical-test/ru ... iding-test
also bikes acceptable
www.dft.gov.uk/motorcycle-test-vehicle-list/
Stockko
Hi both,
You'd think it would go in the grove however there's nothing holding it in just moves around freely? Didn't seem correct to me...
I'm installing the restrictors to meet the A2 license requirements. I have the certificate which I can sign off my self. If I wanted to use the bike for the test I would have to have an authorised dealer install and sign it off, however I won't be doing the test this bike so not a issue.
crookzy1
Then perhaps your restrictor washers are the wrong size or the rubbers are. Have you tried another rubber? What's the diameter of your washers? Should be 34mm
This may help https://www.youtube.com/watch?v=96MBseb4B4Y
Stockko
Doh... was putting the restrictors in the top groove not the bottom.crookzy1 wrote:Then perhaps your restrictor washers are the wrong size or the rubbers are. Have you tried another rubber? What's the diameter of your washers? Should be 34mm
Thanks for your help!
