NC35 unknown plug near battery
Had the bike for a few years, been trying to get her on the road. Been having troubles with bike misfiring on one (i think) cylinder. Battery is knackered as I've had it on charge for the right amount of time yesterday and got about 10 seconds of trying to start the bike out of it. Took battery out and I just realized this plug....
http://imgur.com/g0uSsrJ
Don't tell me something needs to be plugged into that...
- fourfingers
- Bike owned: NC30RK,NC35RR
Re: NC35 unknown plug near battery
Nothing really important, just the rectifier/regulator that charges the battery
Check this post out, with pics. They are down under too
. Cammo is the ONE down there.
- Bike owned: VFR400
As first guess it looks like the rect/reg unit plug. In your picture I cannot see a rect/reg unit fitted on the vertical plate immediately to the left of the un-connected plug. No rect/reg, no charging battery although it also sounds like the battery is stuffed.
Gaaaaaaahhhh
god dammittt
Got a Lithium battery on the way.
Fourfingers theres no link in your post
So far i've read my best bet is to get a 2002 to 2005 R6 reg??
Cheers lads
god dammittt
Cheers lads
- fourfingers
good read, thanks for the link!
So far I've found this reg that sounds good
http://www.ebay.com.au/itm/Yamaha-Regul ... SwWTRWuArs
Not sure if its still a cheap chinese knock off though?
Who knows, P/N should start with FH if newer FET type and SH if older SCR type. SCR type can be reliable if mounted appropriately, my SCR type has provided >4 years and 30,000km of service. FET type tend not to care how they are mounted, hence their popularity as a replacement.
my 1989 type 2 seed still has the factory rectifier on it.. 40,000km on the clock.magg wrote:Who knows, P/N should start with FH if newer FET type and SH if older SCR type. SCR type can be reliable if mounted appropriately, my SCR type has provided >4 years and 30,000km of service. FET type tend not to care how they are mounted, hence their popularity as a replacement.
interestingly, not many people know this but you might like to know, The NC30 was subject to a factory recall in around 2001.. the reason was the soudn foam on the inside of the rear cowl by the reg/rec deteroiates and blocks air-flow around teh reg/rec increasing chance of failure.
the recall just changed the foam
