Low/high beam switch stuck
- Bike owned: NC21
Couldnt find any thread on that, so my low beam/high beam switch is stuck on high beam and cant switch onto low, also the passing button doesnt work? disassembling it and spraying it with contact spray? any advice
- Bike owned: VFR400
Re: Low/high beam switch stuck
disassembling it and spraying it with contact spray? Yes.
nc21 uses only 1 h4 bulb so it shouldnt melt the switch unless you have put an over-wattage bulb in, if its a normal h4 then as magg as already pointed out its probably just crap in the switch so a straip and clean should sort it.demerdzhiev wrote:Couldnt find any thread on that, so my low beam/high beam switch is stuck on high beam and cant switch onto low, also the passing button doesnt work? disassembling it and spraying it with contact spray? any advice
- Bike owned: NC21
fixed* there was this little plate in the switch (it's pushing the guide for the slider) that needed to be bent in its original position, everything lubricated and now works perfect.
- Bike owned: AR 125, NC30
Anyone know where to get a replacement headlight switch (on right bar) for a VFR400 L?
I looked at Wemoto but they don't seem to have it and David Silver's parts list is an enigma to me (if I get stuck I'll call though...)
And some aftermarket red button jobs look a bit sloppy
Any pointers appreciated
s
s
