GK73a Parts Compatability
kailoren
Post by kailoren »
Hi everyone, i'm in the process of rebuilding a damaged GK73a and it pretty much goes without saying that trying to get a hold of decent parts without having to buy an entire 2nd bike is pretty much impossible.
So i wanted to ask you all if you know of any other suzuki's (im thinking along the lines of bandit/fzr perhaps) which have parts that will fit the GK73a with little or no modification. Mostly things like forks, rear shock mounts, footrests, bars, carbs etc
Any help will be greatly appreciated, thanks!
Variablevalves suck
Re: GK73a Parts Compatability
Post by Variablevalves suck »
Ive a lot of stuff.
If you decide what you are looking for and PM me a list i will have a dig.
deffo got a mint set of forks.
Chris.
kailoren
Post by kailoren »
I definitely need a set of forks as the ones that are on it are all pitted and seals are shot. I've been reading that you can put an old 750 oil cooled Slingshot engine in them, and im thinking of using either one of them or a 600 SRAD engine instead of the 400 engine so if anyone has had any experience with putting some bigger engines in the 400 frames any advice would be great!
Are your forks the original or are they from another bike? I know they are quite short and was debating using 600 forks on it instead to go with the larger motor im planning on putting in
Variablevalves suck
Standard forks.
Might be wrong but don't think the bigger engine fits the 73, ive seen them fitted to the 76 with its cradle frame but not the 73.
Seen a srad fitted to the bandit and it had serious frame re work and the bandit and 73 share casings.
N88GUM
One Hit Wonder
Post by N88GUM »
Is there a list of front fork swaps for the GK73a
Variablevalves suck
They are 41mm so there are options but if any would drop straight in without work is debatable.
Jap bandit400, katana 400 or other Suzuki grey 4’s will fit but are probably slightly longer, they share wheels and callipers so only the length will differ.
