nc30 engine rebuild
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
nc30 engine rebuild
Hi,
I bought this engine block today and the seller claims that the piston rings, main bearings and connecting rod bearings have been replaced. The engine block is incomplete and comes with the parts seen in the photos.
My plan is to strip the parts missing from it (heads, sensors, generator, waterpump, sump side covers and so on) from my old engine and use them to build this one up.
My old engine is running ok but is down on power (49Hp) and is eating 1l of oil or more per 1000km. What parts do I need to get for this build?
Here's the block that I bought:
http://s18.postimg.org/5xkcp8hxz/image.jpg
http://s18.postimg.org/mk1wybavr/s_l1600.jpg
Regards,
Chris
Regards,
Chris
hunter
Re: nc30 engine rebuild
Sounds like you just need a gasket set.
Make sure you use OEM Head gaskets.
krisztian_andre
Cool.
I will also need to refresh my old heads. What's the recommended method of removing carbon deposits, what kind of lapping paste should I use and do I have to remove the camshafts to lap the valves and replace the stem seals?
krisztian_andre
How about Vesrah gaskets? I've heard they were the original supplier of these parts.hunter wrote:Sounds like you just need a gasket set.
hunter
This will require a complete head strip yes.krisztian_andre wrote:Cool.
Fine paste will do you.
Reason: fixed quote
Reason: fixed quote
hunter
I have heard the same thing myself,krisztian_andre wrote:How about Vesrah gaskets? I've heard they were the original supplier of these parts.hunter wrote:Sounds like you just need a gasket set.
But have never tried them.
krisztian_andre
What about rebuilding the head. Do you normally have to measure or replace valve guides?
lukemillar
I usually measure them but have yet to find one that needs replacing so you should be fine
krisztian_andre
Can you tell me what type of gauge I could use?lukemillar wrote:I usually measure them but have yet to find one that needs replacing so you should be fine
richyrd5
bore gauge(small bore gauge)
