Nc24
dudleygareth
Nc24
Post by dudleygareth »
Hi guys I have an nc24 which I'm busy fixing up as a project.Im new and glad too be here for advice.My nc is running hot fan takes a while too come in,in fact I never heard it come in.Checked fan works with direct power,took out thermostat which was abit stuck as way
water is dark brown.Flushed radiator as well but water stays brown.Im sitting with question is there any circulation?
richyrd5
Regular Member
Re: Nc24
Post by richyrd5 »
Could be blocked up with rust/sludge...take water pump of is best and have a look at impeller/condition of it and also check hoses.chances are it will need to be de-scaled and cleaned.
dudleygareth
Re: Nc24
Thanks will do the that
dudleygareth
Re: Nc24
Hi there guys I checked perpeller it's all tight but I think I left bike in gear shouldn't it still be free even if in gear
dudleygareth
Re: Nc24
richyrd5
Regular Member
Re: Nc24
Post by richyrd5 »
I've seen worse but looks ok..best to just spin it over on starter quickly to see if it spins..you wouldn't be able to turn it by hand anyway...check hoses and flush them through until water is clear
dudleygareth
Re: Nc24
Hi richy I've now put back everything earlier but now I gt everything back seems like I can't change gears at everything all stiff.please help
richyrd5
Regular Member
Re: Nc24
Post by richyrd5 »
Did you take the sprocket cover of or gear lever??..
dudleygareth
Re: Nc24
Yes I took that off too get waterpump screw out.
dudleygareth
Re: Nc24
I took sprocket off
