Gerd rads - Question...
Posted: Sat Feb 20, 2016 7:36 pm
by lukemillar
Hey all,
I have finally got my NC30 out of retirement and it is running well.... so I have decided to start tuning it further! I am currently running Gerd radiators but one thing which is bothering me is how close the upper one fits to the underside of the frame making the intake to the carb very narrow. I saw an RC30 rad the other day which looks like this:
This is exactly what I want to do to my upper radiator as it will open up the intake into the carbs. Has anyone manipulated radiators like this before? I want to do it myself since I don't trust anyone else!
Any advice would be much appreciated
Luke
Re: Gerd rads - Question...
Posted: Sat Feb 20, 2016 11:12 pm
by hunter
That looks like a simple mod.
Posted: Sat Feb 20, 2016 11:32 pm
by lukemillar
Would you... just go gently with a hammer?
Posted: Sun Feb 21, 2016 1:00 am
by Morespeedvicar
I'd be making some sort of wood jigs and take it to somewere with a press. Ali cracks really easy if your not carefull (sorry if you already know this).
Ian
Posted: Sun Feb 21, 2016 1:41 am
by marcus57
My old rad looked like it had just been attacked with a hack saw , not to sure I'd be keen to cut the gerd ones around , I'll have a check and see what's on my current track bike but from the top of my head there are a couple of small home made brackets to drop the rad maybe 20mm
Posted: Sun Feb 21, 2016 11:12 am
by hunter
As marcus said a couple of brackets to drop the rad would be easier.
To do the mod in your pic you would need to remove the fins in that area,heat treat the top rail were you want to bend and dress the ends with a light hammer.
Posted: Sun Feb 21, 2016 9:43 pm
by lukemillar
Yeah - I'll try the brackets first.
Thanks for all the replies
Luke
Posted: Wed Feb 24, 2016 10:37 pm
by marcus57
Excuse the poor picture and beat up rad but this is what I have to give clearance for the ram air duct
Posted: Sat Mar 12, 2016 10:32 pm
by fourfingers
I am currently modding an RC30 upper and a custom lower (to fit a NC35).
I love angle grinders... So cut alu in between the tabs(also removed one tab as needed to mod spacing), carefully removed the upper fins
Cut out a alu plate to fit, JBweld it to the upper water passages, and out to the alu welder to weld the edges of the plate and tab to the rad
The lower is a massive (also dual core as the rc30 upper) that belonged to one of Craig McLelland later Brent Nichol race bikes. I have seen pictures of it installed, but I couldn´t make it fit properly. Even though we get 40ºC summers around here, these two rads together will be an overkill, so angle grinder butcher on the rescue. Will post some pics when back from the welder
