Chain stretch
balen1
Bike owned: Rvf 400
Chain stretch
Post by balen1 »
Hey guys any one know if a brand new chain should stretch unevenly within the first few rides of installing it. It was a bit uneven as soon as I put it on but has gotten a fair bit worse. Not a cheap chain either, it's a did x ring chain from gf racing. Any help would be appreciated. Thanks
Bike owned: VFR400
Re: Chain stretch
Post by magg »
If new chain was uneven on the old sprockets, better option would have been to change sprockets. If a new chain is a tight fit over the old sprocket teeth, then old sprockets could be reused. No chains in Sydney?
balen1
Bike owned: Rvf 400
Re: Chain stretch
Post by balen1 »
No there are but I was getting some other stuff and decided to buy through him. Also I replaced the sprockets with new renthal ones when I replaced the chain. So it shouldn't be stretching the way it has should it?
manicguitarist
Bike owned: RVF400 (NC35)
Re: Chain stretch
Post by manicguitarist »
Short answer - no it shouldn't. Especially if, as you have done, changed sprockets and chain at the same time.
Bike owned: VFR400
Re: Chain stretch
Post by magg »
New sprockets and new chain should not be uneven tension. How did you determine that the tension was uneven.
Re: Chain stretch
i agree.
if something is not set correctly though you can easily ruin a new chain a few km.
i had a pinch bolt come loose and tighten up the chain once and destroyed the chain within 50km and before i noticed (was on the highway) very lucky that when i let of the gas i felt it slow down awfully quick.. glad it didnt ruin the output shaft.
in theory a new chain should have all soft links.. any tight spots must be from the sprokcets?
what did you change / not change and how did you do intial tension?
how does it feel now? what do you mean by wearing uneven?
if you take the chain off does it feel like there are any tight links in it?
balen1
Bike owned: Rvf 400
Re: Chain stretch
Post by balen1 »
Changed both sprockets and chain together with all brand new stuff. Did everything by the Haynes manual. When I say chain stretch I mean that the distance between the chain and underside of the swingarm is uneven as you turn the wheel. Haven't takin the chain of to check yet but was all good when I put it on. I tensioned the chain so there was just enough movement to just touch the under side of the swing arm.
Thoughts?
manicguitarist
Re: Chain stretch
Get a chain monkey...makes setting the tension easy.
Bike owned: VFR400
Re: Chain stretch
Post by magg »
Did you buy the GF racing DID525VX2 GOLD X RING chain, interesting that I can only find a 525VX chain on the DID website. The side links have DID525VX stamped on them? You used a riveted joining link? In your first post you said the chain was a bit uneven when first installed.
manicguitarist
Re: Chain stretch
Also with the friendly power level and delivery of the V4 400 - it shouldn't stretch any chain at first - even the very cheap ones.
M
