RO Road Needle question
mattvfr400
Post by mattvfr400 »
Does Ricks needle set need 2 0.5 washers or 1? I have 2 on the standard needles for the fueling.
fatpete
Bike owned: NC35 (RIP), CBR900RR, NC 30
Re: RO Road Needle question
Post by fatpete »
1 I believe, that's what I am running anyway.
mattvfr400
fatpete wrote:1 I believe, that's what I am running anyway.
Cheers fella. Did you notice much improvement after installing them?
fatpete
Post by fatpete »
Not a huge amount as I did several other mods at the same time so it's hard to say what effect they made, but the originals were worn so needed replacing anyway. Certainly not found any problem with them, but the bike does need some dyno time to get it just so.
Happy I got them but will be interested to hear if they make much of a difference for you.
RickOliver
Post by RickOliver »
Those needles are a straight drop in replacement for the originals so use the standard 0.5mm stainless washer but no extras...
Rick
richyrd5
Regular Member
Post by richyrd5 »
Rick.are the shims needed for the hrc kit a.b.c needles?(rvf carbs)
mattvfr400
RickOliver wrote:Those needles are a straight drop in replacement for the originals so use the standard 0.5mm stainless washer but no extras...
Rick
Appreciate that Rick. Cheers.
RickOliver
The RVF kit needles have a circlip and 3 grooves for height adjustment (the VFR ones just have a plain flange built into the needle like the stockers) - the grooves are 1mm apart so the kit just has 4 x 0.5mm spacers to give you an optional height increment of `half a groove` for fine tuning if required.
richyrd5
Regular Member
Post by richyrd5 »
RickOliver wrote:The RVF kit needles have a circlip and 3 grooves for height adjustment (the VFR ones just have a plain flange built into the needle like the stockers) - the grooves are 1mm apart so the kit just has 4 x 0.5mm spacers to give you an optional height increment of `half a groove` for fine tuning if required.
Excellent.thanks chap..
