engine numbers
hunter
engine numbers
Post by hunter »
hi all new here,
been looking around, snooping about for a wile,thought i'd better show myself :scared:
real good site this( lot ov good stuff) anyway got a question, how can i identify a 400sp
motor,what should the crankcase stamp read, thanks. :) :) :)
dobbslc
Re: engine numbers
Post by dobbslc »
As for as I know the 3tj engines sp & rr all have 1wg only stamped on them & no other numbers. ;)
Re: engine numbers
Post by Evilchicken0 »
There's a take off for the oil cooler I think it comes from the oil filter housing
hunter
Re: engine numbers
Post by hunter »
so what's a 4dx.
oollit
Bike owned: FZR400RR 3TJ, RF900R
Re: engine numbers
Post by oollit »
A 4DX is a UK spec 3TJ.
I only please one person per day.
Today is not your day, tomorrow isn't looking good either.
plodder
Re: engine numbers
Post by plodder »
My engine only has 1WG on it. I thought maybe something was wrong with the bike's identity but it matches the V5.
Motorcycle Solutions
Bike owned: Kawasaki ZX9R E1
Re: engine numbers
Post by Motorcycle Solutions »
if the 4dx engine has two pipes comming from the oil filter it is an sp if does not then it is an rr motor.. but lucky enough the 4dx sp and 3tj rr has the same amount of clutch plates 8 in total sp has nine which is a pain for you hane to buy two packs of clutch plates..
Re: engine numbers
The 4DX is a European spec 3TJ and I think all the 4DX have an oilcooler ... making it a bit of pain identifying them from the SP.
I guess the best way to tell an SP is to take the clutch cover off and count the plates
rrsp
Bike owned: fzr600-,yzf750-,owo1,750
Re: engine numbers
Post by rrsp »
you could pull the rocker cover off as the valve spring are colour coded yellow for an sp & green for a rr, !
dobbslc
Re: engine numbers
Post by dobbslc »
You can't see the springs without taking the cams out! The clutch has an extra plate though 9 I think for an SP. :D
