Tyga exhaust install
- jpete41996
- Bike owned: VFR 400
I am installing my Full Tyga exhaust system on my VFR400, but am not using any silicone sealant around the joints, as the instructions suggest. Anyone with Tyga exhaust experience, does it leak? Should I use something to help seal the exhaust? Thanks.
If i can wrench on cars, bikes should not be a problem, right?...
hunter
Re: Tyga exhaust install
I think the answer to this is in you instuctions.
- Variablevalves suck
Tool station and the like sell heat resistant silicon for £5 so mot an expensive job.
racingt
- Bike owned: NC35, Shand Stoater plus
Put mine on in September without silicon sealant, but used copaslip on the joins. Works perfectly.
Did you get instructions then??
Dynamohum
Are the joins not designed to be an interference fit to allow for expansion/contraction hence the spring hooks at the pipe joins would think anything other than copaslip like silicon or worse still firegum might be problematic would stick with tyga instructions.
- jpete41996
Yep, I just took the joins off and used some high temp silicone. Was really just wanting for an easier removal when needed. Started it and no leaks so happy days. [img]http://images.tapatalk-cdn.com/15/11/15 ... 6a412f.jpg[/img]
- jpete41996
And one more cause I am pretty happy![img]http://images.tapatalk-cdn.com/15/11/15 ... 78a88f.jpg[/img]
- jpete41996
I just looked at the instructions on the Tyga website.racingt wrote:Put mine on in September without silicon sealant, but used copaslip on the joins. Works perfectly.
I never used any silicone when I have installed my exhausts. Just copaslip
- jpete41996
I looked up copaslip and I would have gone that route if I knew about the product. I recently moved to Germany, so I'll have to have a look for it here, or just order some in from the UK.
