GK76 Fuel tank/tap
Posted: Sat Aug 29, 2015 11:20 pm
Hi Guys, Ive only had the bike two weeks so bear with me if I ask some real dumb arse noob type questions
Ive just removed the fuel tank for the first time. What an arse it is getting those hoses off and back on the fuel tap with the limited slack in the hoses. Any tips greatly appreciated. In particular I struggled with getting the rear hose on to the back of the fuel tap. There's just not enough clearance to get your hands in there.
Im assuming the two large diameter hoses coming out of the tap are fuel supply lines to the carbs - one for the tap in prime and one for tap in On/Run? So is the smaller diameter hose coming out of the right hand side of the tap for vacuum then?
The guy I bought the bike off told me to switch the tap to prime for starting the bike then flick it back to 'on' once started.
Any need for this? I'm not really sure what the prime position is for...
I'll sneak in one last question and its a bit of a biggy but the bike appears to be running a bit rich (black plugs and pipe). In general where is the best place to start with this? I'm guessing jets or needle heights but I'm limited on carb knowledge.
Is it possible to work on the carbs in place or do you need to remove the bank? It's damn tight in there, looks like a bit of a mission! As you can tell, I'm used to working on singles and V twins.
Thanks in advance for any help you may wish to offer.
