Rectifier loom melted nc30
beastybikes
Just took fairing off to get to radiator to check if fans working or temp switch is as starting overheating quickly in traffic or slow speeds and come across this. rectifier end is ok but as can see in pic this is foooked.rectifier has at some point in life had a yamaha r6 rectifier put on.can this be snipped and new connecters put on and soldered? ? Ideas
beastybikes
beastybikes
- bikemonkey
Re: Rectifier loom melted nc30
Full charging system check first.
You may have a buggered alternator or Reg/Rec.
After that check this out: viewtopic.php?f=24&t=37039&hilit=chargi ... em+upgrade
- GeeTee
- Bike owned: NC30 & GSXR750K4
My trackbike fried it's wiring a few weeks ago. I fitted a new DIY wiring harness and connectors to bypass loom. Fortunately the generator and regulator were not damaged and it's charging fine again now.
viewtopic.php?f=24&t=50472
that connection always goes on old bikes with exposed connectors.. the corrosion over time causees it to build up resistance and then the extra power needed to overcome it heats up the connector and melts it.
cut the bad stuff off and solder some good connectors on there, I use AMP type waterproof connectors to prevent future corossion.
After a repair as above check the charaging system.. sometimes the extra current draw can burn out your stator.
- vfrman
- Bike owned: NC30, 1098s
Neosophist wrote:that connection always goes on old bikes with exposed connectors.. the corrosion over time causees it to build up resistance and then the extra power needed to overcome it heats up the connector and melts it.
I've pretty much swapped all my stock connectors over to AMP.
