Rcg /Rec Faulty
savfr
Rcg /Rec Faulty
Hi
is this a dead rec/reg???... Traveling home from work with the lights on and the bike starts to jerk, switch to park beam and it's ok as soon as i switch to normal beam the bike splutters and jerks and wants to die. ??
If so what replacement can i use? Ive heard the one off an R6 is a better one to use.
bridgey
- Bike owned: NC30,CG125 FJS600 SILVERWING
Re: Rcg /Rec Faulty
Have a search. I had some probs with mine and got loads of help. The thread was called 'help!! do i need a new reg/rectifier'.
Good Luck
AL
Good Luck
AL
400GB MCN Fantasy League Champion
wullvfr
- Bike owned: zx9r c1
Re: Rcg /Rec Faulty
have you got a multimeter?
get the battery charged up fully then do some simple checks.....
1st check what the charge rate is...@5000rpm it should be 13.5-15.5volts
now if the reg rec is gubbed then the volts should actually drop instead of rising.
william
william
savfr
Re: Rcg /Rec Faulty
Thanks will do
- jo
Re: Rcg /Rec Faulty
Rick Oliver is the man to speak to about getting a replacement. He gets heavy duty ones. He's a member on here so send him a PM or email...savfr wrote:Hi
savfr
Re: Rcg /Rec Faulty
Thanks jo , but i live in South Africa.
The exchange rate would kill me 16:1
I can get a R6 Reg\Rec for R400 , (+- ₤25)
from a local guy.
from a local guy.
wullvfr
Re: Rcg /Rec Faulty
if it turns out to be the reg rec faulty then that is your best option!!!!!!!!savfr wrote:Thanks jo , but i live in South Africa.
from a local guy.
william
- jo
Re: Rcg /Rec Faulty
this is where the "location" part of your profile comes in handy so we know where you are!savfr wrote:Thanks jo , but i live in South Africa.
- hannakournikova
Re: Rcg /Rec Faulty
not everyone will pick up on the SA in your name.
