NC24 Float Needle
andyrac
NC24 Float Needle
Hi All
Is the float needle male and female part the same as a NC30 one.
Cant find a listing for one anywhere, unless anyone knows where to get one
Re: NC24 Float Needle
where exactly did you look?
16011-ml0-004 - float valve needle set (discontinued)
nc30
16011-MR8-003 (available)
different part numbers but not sure if it is compatibile
nc30
andyrac
Thanks for the heads up, can you recommend somewhere for carb parts
What parts are you after? and where are you?andyrac wrote:Thanks for the heads up, can you recommend somewhere for carb parts
davidsilverspares / lings honda / Rick Oliver (Forum member) / cmsnl are all places i'd try.
Not a lot of stuff is avaiable new and parts you can still get can be very expensive
