Regulator
JamieDemos
Regulator
Hi all, I replaced my regulator about 2 months ago at a local bike shop, the one they replaced the original with looked similar to the original but had no branding or anything. 2 months later it has now failed. Can anyone recommend a regulator to buy online that will actually last. Also if I purchase it online about how long would the part take to arrive?
manicguitarist
- Bike owned: RVF400 (NC35)
Re: Regulator
Rick Oliver does a good one.
However, when the reg/rec is replaced it is essential that it is fitted correctly - i.e. is very flush against the frame as it used that as a heat-sink. It is the excess heat that kills them.
Also - if the battery is old or weak then that will also put extra strain on the reg./rec - so you should have had a new battery fitted
Also useful is the reg/rec modification where you run the wires direct to the battery.
JamieDemos
Re: Regulator
Hi, I did replace the battery at the same time. Is the modification you are referring to you in the documents section?
- jim157
Re: Regulator
The mod was detailed in Practical Sportsbikes. The only reference online I could find was here:-
http://www.hondahornet.org.uk/messagebo ... 60&t=31992
Saying that I believe someone on this forum might have done the mod but I cant find it.
Here's the bits you need:-
http://kojaycat.co.uk/Honda-Rectifier-Regulator-Mod
AUTOEXEC.TWAT
manicguitarist
Re: Regulator
I've done the upgrade. Took about 2mins. Voltage at battery increased from 13 to 14.6v
beastybikes
Re: Regulator
from practical sportsbike mag-
lutorm
- Bike owned: NC23, NC30
Re: Regulator
I replaced my reg with a CBR600 one and re-did the wiring since mine was melted. Not exactly bolt-on, but this one runs cool to the touch: http://blog.familjenjonsson.org/blog/20 ... -rewire-1/
- GeeTee
- Bike owned: NC30 & GSXR750K4
Re: Regulator
Mine has just fried it's charge circuit wiring
I will be running a new section of loom to bypass the original connector
JamieDemos
Re: Regulator
Haha sorry GeeTee, I went through that twice. Thanks for the advise everyone.
