gk76 carb refurb kit
Posted: Wed Jul 08, 2015 9:25 pm
by jamestaylor92
I can imagine this topic has gone over a thousand times but my search revealed nothing. My bike pulls through the rev range fine however if Im stationary and rev the engine the revs drop , stick around 4k for a fair few seconds and sometimes cutting out , ive come to the desicion its the o rings *shock*.
What i want to Know is there a place i can buy a complete carb refurb kit?
Note it isn't an SP model
Re: gk76 carb refurb kit
Posted: Wed Jul 08, 2015 11:11 pm
by Variablevalves suck
Yes mate contact Blair at litetec he posts on here and reproduces all the seals for the gsxr.
Posted: Thu Jul 09, 2015 7:40 am
by willandrip
Posted: Tue Jul 14, 2015 8:22 am
by greybiker
Hi can anyone please tell me can i fit any other carbs to the gk76 im fed up with mine costing me alot of road time
Posted: Tue Jul 14, 2015 8:25 am
by jamestaylor92
Thanks chaps
Posted: Tue Jul 14, 2015 1:29 pm
by wullie3xv9
greybiker wrote:Hi can anyone please tell me can i fit any other carbs to the gk76 im fed up with mine costing me alot of road time
If you buy & fit both of Blair's LiteTek GK76 seal & gasket kits that should eliminate the vast majority of running issues.
The problem with buying a different set of old carb's is that you can end up with similar problems due to ageing / dried out Nitrile seals & gaskets & worn needle's & needle jet's.
If you haven't bought the two LiteTek kits yet, DO IT. I did & they made a big improvement to how my GK76 now runs, especially below 4,000 rpm. Mine is still not perfect, but, new OEM needles & needle jets I've ordered should sort that out once & for all. ( I ordered the needles through my local Suzuki dealership & the stock Mikuni 643 Series O-5 needle jets I ordered from NRP carb's in Manchester, U.K. as they are "No Longer Available" from Suzuki ).
Posted: Tue Jul 14, 2015 2:49 pm
by greybiker
The plastic slide covers are broken where can i find them
Posted: Tue Jul 14, 2015 4:57 pm
by willandrip
greybiker wrote:The plastic slide covers are broken where can i find them
Under a gooseberry bush ?
Most would either source used parts from breakers or new parts from a dealer if still available though.........
one gets prickled less .!
If you mean the caps for the top of the slides;
13502-33C00.
They are NLA but were also fitted to carbs on 1994-96 Suzuki RF600R and RT models which enlarges the search for used parts advantage only slightly.
If not smashed to pieces and many bits missing they may be repaired using a product called Q bond.
Hold the bus; They MAY be obtainable on back order...../
https://www.fowlersparts.co.uk/search/p ... -33C00-000
Also a ghost thread resurrection;
viewtopic.php?t=47606&p=344279.
Ebay here;
http://www.ebay.co.uk/itm/SUZUKI-GSXR-4 ... 56777033e5
..Cheap enough ?
Damaged but could be repaired; Ad says undamaged but blurred pic looks like damage at mount in bottom ?
http://www.ebay.co.uk/itm/Suzuki-GSX-R- ... 1c480db6e6
