Jetting problems on NC30
Posted: Fri Jun 19, 2015 6:41 pm
I'm having a little trouble jetting my NC for a ram air/open airbox.
Currently running NC30 carbs:
150 mains
35 pilots
RVF HRC needles (was way too rich with the RO NC30 needles)
Slides drilled
5 hole emulsion tubes
Spec of the bike is:
NC35 motor
NC30 pickups
Ignitech cdi running a HRC map
Gas flowed & skimmed heads
Two Brothers exhaust system
Fuel pump off a CBR600
Motor was tuned & built by Slick Bass in the IoM, and was refreshed recently.
This is one of my dyno charts from this week:
The red line is with a 1mm air corrector jet, and the blue is with a 2mm air corrector.
From reading what other people jet their bikes at with open/ram airbox, using the air corrector jets enables IRO 135 mains, but I'm on 150 and still looking lean even with a tiny air corrector?
That lean spike at 10-12k, what could be causing that? Slides opening too soon & the main jet is unable to keep up?
I'd appreciate any input, its had some weird jetting since I've bought it but was producing a healthy 66hp before I started fiddling with the airbox, but even then the fuelling was far from perfect!
150 mains
35 pilots
Slides drilled
NC35 motor
NC30 pickups
