Page 1 of 2
Need help with nc35
Posted: Thu May 28, 2015 12:18 pm
by leevon
Hi guys. I got a problem with my bike i just did my clutch plates and putt it back to gether. The thing that i wane ask if your wheel must lock if its in gear? Goz my wheel dont lock i can push my bike around in gear but it push a lilbit heavy... Must tje bike be like that or not and what can be the problem?
Re: Need help with nc35
Posted: Thu May 28, 2015 4:59 pm
by richyrd5
yes if in gear the wheel should lock. and you shouldnt be able to push it while in gear with clutch out!!sounds like you have put the clutch back together wrong somewhere along the line!! did you have a manual when you stripped it?
Posted: Thu May 28, 2015 9:16 pm
by CRM
no need to post it 3 times in different areas
sounds like it needs to come apart again. thats not right
Posted: Thu May 28, 2015 11:37 pm
by hunter
It could be that with new plates the cable needs to be adjusted.
by hunter
Posted: Fri May 29, 2015 7:58 am
by leevon
The stuff aint rocket scince i did took the clutch plates out more than 12 times doing it over and over its 9 clutch plates and 8 metal plates i evan haf it at a shop so that they can put it together and still does the same but if i pull the bike back it locks but not if i push it to the front, and the stuf can only go one way up i first thought that the airgun cant shoot the lock nut tight but i f#@k up 2 nuts trying to shoot it tighter an still no luck
Posted: Fri May 29, 2015 8:13 am
by Variablevalves suck
If you are 100% sure it built up right then id be measuring the plate thicknesses to make sure they are correct.
In fact id measure everything.
Posted: Fri May 29, 2015 8:44 am
by leevon
I only bought the clutch plates do u realy think the metal plates can make that problem? Or must i take the whole rigth part out the gears everyting and put it back again coz i realy cant put my mind on it iys like the clutch lock nut must be tighter but it cant go tighter... And i sent my clutch so just before it pushes the rod back im realy fed up with ima start the bike and drive it and see what problems it gona through back in my face.. coz as it is now the clucth are sliding ive try to put another metal plate in to what gona hapen but it doesnt work im ready to try anything ill evan light the b!tch up in flames!!!
Posted: Fri May 29, 2015 8:48 am
by CRM
put the original clutch back on and if normal then you know the parts your bought are shite.
replace with OE parts or exchange for correct bits.
Posted: Fri May 29, 2015 4:39 pm
by leevon
Dont have them but will buy a new set
