CARB PIN OR NOT TO CARB PIN THAT IS THE QUESTION
minkathecat
Bike owned: honda 600rr / z200/honda horne
Post by minkathecat »
https://www.youtube.com/watch?v=lZd539zd1xo
SOME ONE TELL ME IF THEIR SHOULD BE A PIN IN HERE OR IS IT THE PILOT JET AIR HOLE FEED?
COS THEIR IS ANOTHER LITTLE JET WHEN U SCREW OUT THE PILOT HOLE EMBEDED IN BEHIND
PUSH CATGUT IN THE FRONT HOLE WHERE I THINK THEIR SHOULD BE A PIN AND IT COMES OUT ROUND THE SIDE OF THAT EMBEDED IN JET UNDER THE PILOT JET :whistle:
AND IF THEIR SHOULD BE A PIN IN HOW LONG?
rgvsp
Bike owned: RGV250SP (VJ23) GSX-R400R
Re: CARB PIN OR NOT TO CARB PIN THAT IS THE QUESTION
Post by rgvsp »
No pin goes there, it is an open hole. The pilot's are in the opening on the right, way down in there. The opening you are showing does not have a jet screw into it.
minkathecat
THANK RSGP
Just found that out today after a bit of searching around the two other jets one under the pilot was not that clean and their is a slot at the side of it near its base so air is pulled into this from the hole i thought was blocket and mixed with the fuel going across into the pilot jet under the pilot jet if u get my meaning cleaned out the opposite side also the emulsifier thats down that ajacent hole which screws out so in all thats 2 other jets that r not on tony sleeps carb paper on here. tut tut
regards john
So i was thinking bollocks lol :peace:
