Fuel tap
james724clapp
Fuel tap
Really simple question.
I know that the prime position is pointing to the rear of the bike, but which way is main and which is reserve. My tap is not marked and I don't really want to run out to find out!
I would be grateful for any advice.
james724clapp
Re: Fuel tap
Oops!
Bike is a 1990 GSXR400R GK76a
martinsamuel
Re: Fuel tap
If i remember right. 'Reserve' is toward the front, 'On' is the center position and 'Prime' is toward the back. Both the on and reserve require vacuum to operate.
willandrip
Re: Fuel tap
If the tap body has no on/res/prime letters marking on it ;it may be from another model and it may be that
the instructions just given above are incorrect.
The 76a tap has this identification......some of the other Suzuki taps with 2 outlets have no instruction but can be used to replace a dodgy tap.It does not always correlate to the lever position being the same.
Carry some spare fuel in a container and ride round until you find which position is which.
Better still would be to remove and service the tap/work out the orientation.... those internal tank filters will appreciate it.
