Help Help Help !!!!!!
mollers
- Bike owned: 1990 NC30 uk, 2002 Blade 954
Evening all,
Prat that i am
i Have gone and lost my only bloody key for my NC30
Can i get a replacement from Mr Honda without knowing the key number ?
Can anyone advise or is it a whole new lock set ??
Chris
Prat that i am
Chris
dobbslc
Re: Help Help Help !!!!!!
Probably best to get new a pattern lock set from wemoto or Buster' s etc.
Will be cheaper too.
newtothis
- Bike owned: YZF R125, RVF400, Morini 3 1/2
There's a very slim chance that Honda might be able to look up the key code from the chassis number, but I wouldn't hold my breath. A decent locksmith could impression the lock and cut a key to suit but it's probably cheaper to buy a new lock set than call one out.
Icemaestro
Wasn't there a guy on eBay who could cut to a code on the ignition barrel?
dgunthor
as above, i thought there's a code printed on the ignition barrel - can get a key cut from honda from this
mollers
Thankyou for all the reply's guys, will get me arse in gear.
Many thanks
Chris
Many thanks
Chris
- RickOliver
Three possibilities for you -
1) The key number is stamped on the ignition lock, but you have to cut the plastic outer casing off to see it.
2 If you`re confident that your bike still has it`s original matching locks you can remove the fuel tap and shine a torch inside the tank to read the key number which is also stamped on the underside of the filler cap.
3) Express Keys in Orpington ( http://www.express-keys.co.uk/ ) can cut you a new key if you send them your ignition lock - I work for a Honda main dealership and that`s who we use...
Rick
Rick
mollers
Thanks Rick
Great information. Will get my torch out and have a nose.
- jim157
RickOliver wrote:Three possibilities for you -
Rick
Rick, I dont suppose you'd know if this applies to most Honda's? Reason being my CRM doesn't have it's original matching fuel cap so the ignition key doesn't fit. Does this look like it could be the Honda key number?
AUTOEXEC.TWAT
