Water pump leaks to the oil?
Posted: Tue Feb 17, 2015 3:22 am
Hi guys, I have been working on my NC31.
Few months back I replaced head gasket because milky oil was found & losing coolant & overheated. Did the oil & coolant change when I closed everything and it runs fine - no bubbling from radiator nor losing coolant. Changed oil again after one month and it still looks a bit milky. I thought it would be clean after few oil changes.
Everything's fine until recently I start to lose water again - one time I found coolant low in reservoir then top it up to "max" line. I'd ride for 30 mins and there was more coolant in reservoir and makes sense to me. However I let it cold for overnight the level is between max and min which means 50-100cc lost. This happens every ride I need to keep filling reservoir.
Opened rads cap when it's still warm (one hour after ride) and its not full (missing about 50-100ml i think). so I put the cap back and let it overnight - the rads is full again and reservoir is less water so it's sucking coolant.
unlikely HG failure to me - not again!
would it be the water pump leaks internally into oil?
or maybe just externally leak from the hoses that I've not found yet.
thanks for your help in advance.
