Exup valve
Posted: Fri Feb 13, 2015 5:46 pm
by redbandit12
Stripped the valve as its rattling its nuts off at tickover (putting a bit of pressure on the pulley stops it).
Bushes have worn into an oval shape.
A mate of mine will make me a new set up, but the 'dust seal' has fell to bits trying to get it out.
Is there an alternative I can use or have made as the price is ridiculous if available.
Also, is it worth buying the little spring as used on the 1000
Re: Exup valve
Posted: Fri Feb 13, 2015 5:56 pm
by willandrip
It is the graphite bush itself that will have fallen to pieces.
The so called dust seal is actually a steel spacer/washer.
I fit a light duty compression spring cut to length to stop lateral play if it is excessive.
Re: Exup valve
Posted: Fri Feb 13, 2015 6:35 pm
by redbandit12
Its p/n 2Tk-14845-00 that sits above the graphite bush in the housing
http://www.cmsnl.com/fzr600rec-1993_mod ... N5Dg4bfWrU
Exactly the same as the 400 parts manual. Made from aluminium
Re: Exup valve
Posted: Tue Feb 17, 2015 9:10 am
by redbandit12
Just asked Yamaha for availibility but its discontinued.
Any ideas on an alternative or is it really neccessary??
Can have a longer carbon bush made if that will do
Re: Exup valve
Posted: Wed Feb 18, 2015 1:05 am
by Morespeedvicar
I just pressed a bit of brass pipe into the worn out bush...Think it was 10mm I.D.
