				Non sp wheels on a sp
				Posted: Fri Feb 13, 2015 2:53 pm
				by Drunkn Munky
				Is there any actual difference between the sp and non sp wheels on a 3tj? I know sp's have captive spacers but can the captive spacers be fitted to non sp wheels?
				Re: Non sp wheels on a sp
				Posted: Fri Feb 13, 2015 7:53 pm
				by dobbslc
				I think the wheel casting is exactly the same, it's just the spacers and maybe bearings that are different.
				Posted: Mon Feb 16, 2015 12:14 pm
				by 4StrokePete
				Pretty sure the rear is ok, as it can be fitted up with the SP spacers and bearings.
 But the front is different, its been a while, but I think the wheel bearings are smaller
 diameter.
				Posted: Thu Feb 19, 2015 7:06 am
				by bendy3
				4StrokePete wrote:Pretty sure the rear is ok, as it can be fitted up with the SP spacers and bearings.
 diameter.
Right about the front wheel.
The rear wheel spacer on the disc side of an sp wheel is shorter than the rr rear, this is because the sp caliper carrier is different (slightly wider). I machined a spacer from an rr wheel shorter, 2.5mm I think? Don't know if captive spacers can be fitted. Might be worth a try?
