3TJ Silencer Packing.
aceman
Hi Guys. Has anyone re-packed an original silencer before?
Re: 3TJ Silencer Packing.
Can't see it would be that difficult apart from getting a match for the rivets, the originals are a large head size.
You could sent it off to somewhere like PJ Engineering who would do it.
aceman
Thanks for the advice. Will try myself first.
Ok then ...
Drill out the rivets, use a big dia drill bit ... You'll need to measure the size of the rivet hole and replace them with sealed rivets.
Wear heavy gloves.
Clean it with a wire brush.
Put stainless steel wool around the pipes inside then put the wadding in - you can get some that's preshrunk and expands when the pipe gets hot ... Kayla Projection Components sells it.
Rivet it back up
Wear heavy gloves.
Rivet it back up
