Temperature gauge problems
JamieDemos
Hi again. Since I've had my nc30 the temp gauge has never worked properly, sometimes it works, sometimes it doesn't.
I tried grounding the sender wire to the frame with the ignition on and the gauge doesn't move.
What should I do next to find the source of the problem?
richyrd5
Re: Temperature gauge problems
Check the wiring from connector at thermostat housing upto dial.if no joy its a new/replacment dial!!!.(i have a working cbr400.one!!!)
JamieDemos
Thanks, will give it a try
