RVF 400 - Blowing exhaust issue
Nathany94
Hi,
I was wondering if anyone would be able to help me out.
My exhaust is blowing and there is a ticking sound which gets a a little bit louder the higher the revs go.
What would be the best thing for me to do to be able to work out where it is blowing from? I presume the ticking is also a part of the same problem
Thanks!
Thanks!
Re: RVF 400 - Blowing exhaust issue
You get a ticking sound when the rear manifold is loose, id start there but you should be able to tell fairly easy where its blowing from when its running
