Nc24 project
Mpadge89
Nc24 project
Hi I recently baught myself an nc24 off a friend after he has gone onto a bigger bike, when I baught it the front suspension was far too soft so I've upgraded the springs to hyperpro progressive springs, it had an oil leak around the oil pan so I've replaced the gasket fixing this problem, it had a misfire when I baught the bike which he said was down to a bad coil pack so I have replaced these and the bike is in the garage to get the cars balanced, I've also changed the rear section of the exhaust and braided hoses with new brake pads, I haven't had chance to ride this bike yet! But I honestly can not wait!! Just thought I'd put a message up to say hi :)
richyrd5
Re: Nc24 project
Hi chap.looks like your getting things sorted on your bike.nice looking can you got on there...did you have to change the whole rear section of exhaust.or just the can??.ive heard its a engine out job for the rear section??.check your carb rubbers as there known to cause missfires/rough running...atb..
Mpadge89
Re: Nc24 project
Thanks mate will have a look at the rubbers when I get chance, in the pic I've changed the can and link pipe, luckily the collector box wasn't in too bad of condition. Also looking into one of the abs fairing kits from Japan as the fairings I got on the bike are in poor condition. Just can't wait until I can get this bike on the road. :)
Re: Nc24 project
If you'd prefer OEM panels im soon going to be breaking a near complete NC24 and im pretty sure all the panels are there and in decent condition albeit needing paint
Mpadge89
Re: Nc24 project
Sounds good to me :) I don't mind doing a bit of painting. So keep me in mind when your breaking it mate :)
Re: Nc24 project
I'll put an ad up on the site later as the panels are not buried like the rest of the bike but you have first refusal on them.
Re: Nc24 project
Thats the rear downpipes to the collectorbox, from the actual collectorbox to the rear can its just a link piperichyrd5 wrote:Hi chap.looks like your getting things sorted on your bike.nice looking can you got on there...did you have to change the whole rear section of exhaust.or just the can??.ive heard its a engine out job for the rear section??.check your carb rubbers as there known to cause missfires/rough running...atb..
richyrd5
Re: Nc24 project
Ah.thanks neo!
