Front brake master cylinder
Posted: Fri Oct 24, 2014 6:58 pm
Hi Guys,
Has anyone used a 5/8" bore front master cylinder on their NC30 with standard calipers? I rebuilt the calipers on my other halfs bike, fitted braided dual lines, bendix supersport pads and although I feel it is bled correctly the lever is a tad spongey. I have aftermarket "spazzo" levers so perhaps the ratio isn't quite right but they need to be on the largest span setting and the general feel of the brakes isn't sharp.
Perhaps it's the m/cyl that's needing a rebuild, but I was curious about fitting a larger bore before rebuilding or replacing the 14mm std item.
