silencer exhaust gasket
thrushstar
hi i might be sounding like a dumb arse is there a decent gasket to go on my wifes cbr400rr silencer as its started to blow.
- Davez29
- Bike owned: NC29 forever
Re: silencer exhaust gasket
Yes there is, its still available from the usual places for around £6 but you might find that high temp black loctite silicon works OK, especially if its an after market can. I use it myself. With the advantage it can be used as sealant else where.
thrushstar
thank you thats a massive help for such a trivial problemDurka Durka wrote:Yes there is, its still available from the usual places for around £6 but you might find that high temp black loctite silicon works OK, especially if its an after market can. I use it myself. With the advantage it can be used as sealant else where.
- Davez29
lol, no problem, I try to cover all angles.thrushstar wrote:thank you thats a massive help for such a trivial problem
