3TJ Petrol Tank Pivot.
Alex.
Post by Alex. »
On both of the 3TJs in my garage, the bracket on the front of the petrol tank cannot get past the mirror/fairing stay when the rear bolt, by the battery, is still connected.
This seems an obvious design feature to allow it to pivot up, gaining access to the petrol tap and pipe for ease of tank removal.
Both mirror/fairing stays look a bit worse for wear, so I was wondering, should the tank be able to pivot on the rear mounting bolt?
Alex.
All of a sudden I found myself in love with the world,
so there was only one thing that I could do,
was ding a ding dang my dang a long ling long!
Re: 3TJ Petrol Tank Pivot.
Post by Evilchicken0 »
You have thought so wouldn't you ... but no, it doesn't do it on any I've seen.
Thunderbike_steve
Post by Thunderbike_steve »
My race bike does the same thing. Either give it a good clout (thats the aircraft engineer in me speaking) OR take out the rear bolt and lift tank out, slide the front brackets under the fairing stay as far forward as you can and slide the rear back in, should all bolt up nicely ;)
Alex.
Post by Alex. »
Thanks guys, that saved me a couple of quid and hassle of finding a straight unmolested bracket!
Why, oh why was it not designed to pivot!!!
Alex.
